Nx Journaling - Fix a Circle center point from WCS Coordinate System
Kumaresh_07
Automotive
IN
Hi all,
I would like to draw a circle in a point of (X=10mm, Y=10mm, Z=10mm).
The above mentioned xyz values are from wcs coordinate system,Not from Absolute coordinate system.
So kindly anyone tell me -How can i mention in a VB code to fix center of circle (X=10mm, Y=10mm, Z=10mm) from WCS coordinate system.
For your Reference, Please see below code snippet for fixing circle center from from Absolute coordinate system.
Code:
Dim center As New NXOpen.Point3d(10, 10, 10)
The above code would fix the circle center from absolute coordinate system.
But I need to fix circle center (X=10mm, Y=10mm, Z=10mm) from wcs coordinate system.
Please Help me guys ,I m patiently waiting for your replies.
There is code posted in the following thread that has a function to convert absolute coordinates to work coordinates.
thread561-314774
thread561-325985
www.nxjournaling.com
Yes, Abs2WCS function works well...❤❤❤
Thank you Cowski😎.
