NX Open code compatibility
Mika0013
I received an NX Open created tool for NX5, at some point in the code the tool is supposed to ask me to select all the entities in a layer (vertical, horizontal lines, etc). Now the problem Im having is that the line selection window shows up only once, when I click on a line it disappears whereas in a demonstration from a couple years ago the window is supposed to pop up again. Does anyone have an idea what could be the reason for this? Environment variables? Changed NX function names?
By the way, are tool created for earlier versions of NX compatible with the newer versions?
I forgot to ask, if I tried to recompile the code (from the .cpp file) do I need to add all of the header .h files and libraries to run the code or just select "build". In other words, what do I need to make my C++ ready to start compiling codes from an existent .cpp file?
