NX open program running on viewer?
krz177
14
I have wrote a program that sets the assembly load options to specific folders for a particular set of jobs and then opens the selected assembly with these options. The program works great on my box but it was meant to run on the viewer. All of the functions I am using are available in gateway and the program does run about half way letting the user select the assembly they want to open but then errors out when the actual NX functions are called upon in the program. I am using the "OpenFileDialog" function from windows which is the only part that runs.
Is what I am trying to do even possible on a viewer? I assumed it was because it would let me run a signed .dll and I can carry out all of these functions out manually in gateway, any thoughts?
Code:
Option Strict Off
Option Infer On
Imports NXOpen, System, System.IO, System.Windows.Forms
Public Class OpenMssc
    Public Shared Sub Main()
        Dim fd As OpenFileDialog = New OpenFileDialog()
        Dim strFileName As String
        fd.Title = "Open MSSC Assembly"
        fd.InitialDirectory = "T:\Die_Dept\"
        fd.Filter = "Part files (*.prt*)|*.prt*"
        fd.FilterIndex = 1
        fd.RestoreDirectory = True
        If fd.ShowDialog() = DialogResult.OK Then
            strFileName = fd.FileName
        End If
        Dim fileNumberExt As String
        fileNumberExt = strFileName.Substring(12, 4)
        Dim theSession As Session = Session.GetSession()
        theSession.Parts.LoadOptions.LoadLatest = False
        theSession.Parts.LoadOptions.ComponentLoadMethod = LoadOptions.LoadMethod.SearchDirectories
        Dim searchDirectories1(1) As String
'file locations to search
        searchDirectories1(0) = "T:\Die_Dept\" & fileNumberExt & "\" & fileNumberExt & "_dd\"
        searchDirectories1(1) = "T:\Die_Dept\4333_Kanban\4333_dd\"
        Dim searchSubDirs1(1) As Boolean
        searchSubDirs1(0) = False
        searchSubDirs1(1) = False
        theSession.Parts.LoadOptions.SetSearchDirectories(searchDirectories1, searchSubDirs1)
        theSession.Parts.LoadOptions.ComponentsToLoad = LoadOptions.LoadComponents.All
        theSession.Parts.LoadOptions.UsePartialLoading = True
        theSession.Parts.LoadOptions.UseLightweightRepresentations = False
        Dim basePart1 As BasePart
        Dim partLoadStatus1 As PartLoadStatus
        basePart1 = theSession.Parts.OpenBaseDisplay(strFileName, partLoadStatus1)
        Dim workPart As Part = theSession.Parts.Work
        Dim displayPart As Part = theSession.Parts.Display
        partLoadStatus1.Dispose()
'revert load settings back to default option
        theSession.Parts.LoadOptions.ComponentLoadMethod = LoadOptions.LoadMethod.FromDirectory
    End Sub
End Class
Where does your code die? When you call GetSession, I would guess.
Yes, as soon as "getsession" is called it errors out and stops working. This is the log file at that point
NX License Error: License server system does not support this feature. [ -18 ]
at NXOpen.Utilities.BaseSession.InitLicense
at NXOpen.Session.GetSession()
at open_mssc.OpenMssc.Main()
