Hallo everybody,
I am trying to convert a large (CATIA) assembly to NX via STEP214 interface.
My problem is that I need a specific start model in NX, a Daimler conform model.
Is it possible to configure the NX STEP214 converter properly to use a specific start model?
E.g. using the definition file „step214ug.def“ for that purpose?
As a workaround I tried to replace the “step214ugnullnx90_mm.prt” in the subdirectory where
the converter code is stored („STEP214UG“ directory). The result was that the converter also
used this part for the assembly models and the result was nonsense.
Perfect would be a possibility to define model- and assembly-start-part separately for the converter.
Thank you very much.
