NX11 - classical toolbar 17
SOLIERA
26
Generally, this is question directly to John Baker - how to recover classical tollbar layout with NX11?
I know, that Siemens retired possibility switching between ribbon and classical layout, but I belive that exist some tips to allow enable previous one.
Some versions ago was that possibility with Hole Table functions.
To enable Hole Table, if i remember, NX5 or 6 you need add variable UGII_DRAFTING_HOLE_TABLE=1 to ugii_env_ug.dat config file :)
I did something close to John's, but more usable. I actually copied my classic toolbars from an earlier version of NX and added them to one ribbon. I still have assemblies on it's own because it took up too much space.
Ron Dawson
Manufacturing Engineer
Ducommun AeroStructures-Parsons,KS
"Want to eliminate any need to even switch toolbars...
Just turn on EVERY SINGLE ICON, that should do it, eh?"
Good one, John! Love it!
Like capnhook, I deplore excessive clicks but unfortunately classic toolbar configuration and management became a total nightmare for me. I was spending waaaay too much time configuring it like that and if using import it will not account for new menu picks so that's out of the question too. Also I seem to recall a special menu in manufacturing which would not even display in classic! As for the same thing happening in design i cannot be sure. I bailed on classic tool bars as soon as I heard they were obsoleted but I soon found out that heavily customization of the ribbon posed similar problems as the classic toolbar; namely, migration issues. My drafting and manufacturing ribbons look nice but trying to eliminate an extra click or two in the modeling bar proved to be time consuming and I doubt I will heavily customize my ribbon in NX11, other than adding a few custom drop downs.
Making my own drop downs proved completely too time consuming so while in customize mode I simply dragged drop downs from the Menu drop to populate my modeling ribbon; design features, detail features, curve creation/editing, surface creation/editing and synchronous...all in the modeling ribbon but when doing so the drop down display an ugly empty square icon, not a function icon. So the result is quite ugly but it works and it still took some time to set up.
Like I mentioned earlier I will most likely not heavily customize the ribbon in NX11 other than adding a few of my own drop downs and journal buttons. IMO the classic bar's time has passed.
10.0.3
Nice job Dawson70. 60% starting to look more like a classic bar.
Look at all that empty space on the right....awesome..!
Proud Member of the Reality-Based Community..
[green]To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?[/green]
Good job Dawson70! Down to only two toolbars whereas other users have three or more.
10.0.3
Many moons from now when I was young and still had hair, I used to spend time with Inventor. It moved to the ribbon long ago, I and immediately embraced the change and had no problem whatsoever with it. Now that NX did the same I again have no problem with it. Supporting different customers I often have to move from NX10 to NX8.5 and I actually feel mildly annoyed with the classic interface. I think ribbon is better on the whole. Not ideal, of course, but what it? Definitely not the classic interface!
