NX11 - Journal code for changing solid body attributes? 2
Kenja824
Automotive
Nov 5, 2014
949
We had a button that would take the solid body that was already selected, clear all the "solid body" attributes/properties, then add the following properties....
TOOL_CLASS = ALT STD
STOCK_SIZE = ANL217
PURCH_OPTION = P
DB_PART_NAME = NC BLANK
NOTE: This is how I added them through properties...(TITLE/ALIAS = VALUE) I used a string type for all attributes I added.
We are in the middle of switching from NX9 to NX11 and unfortunately this button ran a Macro instead of a Journal. Which now errors out when you run it.
I have tried to record Journals to clear all properties and add these properties but when I try playing them back, they always error out. Saying something about an attribute that is not modifiable so it cannot be set changed or deleted. Which doesnt make sense to me because it allowed me to delete the attributes while recording the journal. lol
Would anyone have any ideas about that or better yet, have code that does the general same thing that I could manipulate to the attributes we need?
Here's one way to do it:
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
    Dim theSession As Session = Session.GetSession()
    Dim theUfSession As UFSession = UFSession.GetUFSession()
    Dim theUI As UI = UI.GetUI()
    Dim lw As ListingWindow = theSession.ListingWindow
    Sub Main()
        Dim markId1 As Session.UndoMarkId
        markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, "body attributes")
        lw.Open()
        Dim selobj As NXObject
        Dim type As Integer
        Dim subtype As Integer
        Dim theBodies As New List(Of Body)
        Dim numsel As Integer = theUI.SelectionManager.GetNumSelectedObjects()
        'process the preselected bodies
        If numsel > 0 Then
            For inx As Integer = 0 To numsel - 1
                selobj = theUI.SelectionManager.GetSelectedTaggedObject(inx)
                theUfSession.Obj.AskTypeAndSubtype(selobj.Tag, type, subtype)
                If type = UFConstants.UF_solid_type Then
                    theBodies.Add(selobj)
                End If
            Next
        Else
            'prompt to select bodies
            If SelectBodies("Select Bodies to reset attributes", theBodies) = Selection.Response.Cancel Then
                Return
            End If
        End If
        For Each temp As Body In theBodies
            DeleteAllAttributes(temp)
            AddBodyAttribute(temp, "TOOL_CLASS", "ALT STD")
            AddBodyAttribute(temp, "STOCK_SIZE", "ANL217")
            AddBodyAttribute(temp, "PURCH_OPTION", "P")
            AddBodyAttribute(temp, "DB_PART_NAME", "NC BLANK")
        Next
        lw.Close()
    End Sub
    Function SelectBodies(ByVal prompt As String, ByRef selBod As List(Of Body)) As Selection.Response
        Dim title As String = "Select bodies"
        Dim includeFeatures As Boolean = False
        Dim keepHighlighted As Boolean = False
        Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific
        Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart
        Dim selectionMask_array(0) As Selection.MaskTriple
        Dim selObj() As TaggedObject
        With selectionMask_array(0)
            .Type = UFConstants.UF_solid_type
            .SolidBodySubtype = UFConstants.UF_UI_SEL_FEATURE_BODY
        End With
        Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObjects(prompt,
        title, scope, selAction,
        includeFeatures, keepHighlighted, selectionMask_array, selObj)
        If resp = Selection.Response.Ok Then
            For Each temp As TaggedObject In selObj
                selBod.Add(temp)
            Next
            Return Selection.Response.Ok
        Else
            Return Selection.Response.Cancel
        End If
    End Function
    Sub AddBodyAttribute(ByVal theBody As Body, ByVal attTitle As String, ByVal attValue As String)
        Dim markId4 As Session.UndoMarkId
        markId4 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "add body attribute")
        Dim attributePropertiesBuilder1 As AttributePropertiesBuilder
        attributePropertiesBuilder1 = theSession.AttributeManager.CreateAttributePropertiesBuilder(theSession.Parts.Work, {theBody}, AttributePropertiesBuilder.OperationType.None)
        attributePropertiesBuilder1.IsArray = False
        attributePropertiesBuilder1.DataType = AttributePropertiesBaseBuilder.DataTypeOptions.String
        attributePropertiesBuilder1.Title = attTitle
        attributePropertiesBuilder1.StringValue = attValue
        Dim nXObject1 As NXObject
        nXObject1 = attributePropertiesBuilder1.Commit()
        Dim id1 As Session.UndoMarkId
        id1 = theSession.GetNewestUndoMark(Session.MarkVisibility.Visible)
        Dim nErrs1 As Integer
        nErrs1 = theSession.UpdateManager.DoUpdate(id1)
        attributePropertiesBuilder1.Destroy()
    End Sub
    Sub DeleteAllAttributes(ByVal theObject As NXObject)
        Dim attributeInfo() As NXObject.AttributeInformation = theObject.GetUserAttributes
        For Each temp As NXObject.AttributeInformation In attributeInfo
            theObject.DeleteUserAttributes(temp.Type, Update.Option.Now)
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        'Unloads the image immediately after execution within NX
        GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately
    End Function
End Module
www.nxjournaling.com
Hi y'all,
I have modified Cowski's journal to get this attribute result but what I desire is to be prompted to enter a string for each attribute (i.e. "MATERIAL", ("") and then I would type material type etc.
PART_NAME = STRING (String)
PART_NUMBER = STRING (String)
TOOL_NUMBER = STRING (String)
DET_NUMBER = STRING (String)
MATERIAL = STRING (String)
STOCK_SIZE = STRING (String)
HEAT_TREAT = STRING (String)
SURFACE_FINISH = STRING (String)
I'm frankly terrible with journaling - is there an easy way to add this functionality?
~Felicia H.
NX 9.0.2.5
"Design all things as simple as possible but not simpler."
Hi Cowski,
The first link you posted is exactly the one I tried to add to (I think) another of your or John Baker's journals but it errors out probably because I'm a daft coder :)
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
Sub Main()
lw.Open()
Dim type As Integer
Dim answer As String = ""
If numsel > 0 Then
End If
Next
Else
Return
End If
End If
AddBodyAttribute(temp, "SURFACE_FINISH", "STRING")
'input box: prompt only
answer = NXInputBox.GetInputString("prompt only")
'input box: prompt and title
answer = NXInputBox.GetInputString("prompt", "title bar caption")
'input box: prompt, title, and initial text
answer = NXInputBox.GetInputString("prompt", "title bar caption", "initial text")
'echo the input
MsgBox("answer: """ & answer & """")
AddBodyAttribute(temp, "HEAT_TREAT", "STRING")
AddBodyAttribute(temp, "STOCK_SIZE", "STRING")
AddBodyAttribute(temp, "MATERIAL", "STRING")
AddBodyAttribute(temp, "DET_NUMBER", "STRING")
AddBodyAttribute(temp, "TOOL_NUMBER", "STRING")
AddBodyAttribute(temp, "PART_NUMBER", "STRING")
AddBodyAttribute(temp, "PART_NAME", "STRING")
Next
lw.Close()
End Sub
End With
selBod.Add(temp)
Next
Else
End If
End Function
End Sub
Next
End Sub
End Function
End Module
~Felicia H.
NX 9.0.2.5
At the top of the code, in the imports section, add the line:
Code:
Imports NXOpenUI
OR
change the NXInputBox references from
Code:
answer = NXInputBox...
to:
Code:
answer = NXOpenUI.NXInputBox...
Hi again Cowski and thank you.
That helped but I'm at a loss for how to proceed further. In the sub below once I select a body I'm prompted to add a string but the string I enter is not being passed to the attribute.
Near the top I have
Then,
AddBodyAttribute(temp, "Detail Number", "")
answer = NXInputBox.GetInputString("")
answer = NXInputBox.GetInputString("Material", "")
answer = NXInputBox.GetInputString("Stock Size", "")
answer = NXInputBox.GetInputString("Heat Treat", "")
answer = NXInputBox.GetInputString("Surface Treatment", "")
'echo the input
Next
lw.Close()
End Sub
~Felicia H.
NX 9.0.2.5
You will want to prompt the user for the attribute value, then pass in the response to the AddBodyAttribute subroutine. Something like:
Code:
answer = NXInputBox.GetInputString("Detail Number", "")
AddBodyAttribute(temp, "DET_NUMBER", answer)
AddBodyAttribute(temp, "HEAT_TREAT", answer)
'add other attributes as needed
Next
Thank you Cowski! It's not perfect but it does what I intended.
I feel like it's calling a Microsoft dialog box rather than an NX and the screen position of it isn't great but it works!
I owe you a cocktail [bowleft]
Here it is for anyone else looking for the same thing:
Option Strict Off
Imports NXOpenUI
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
Sub Main()
lw.Open()
Dim type As Integer
If numsel > 0 Then
End If
Next
Else
Return
End If
End If
answer = NXInputBox.GetInputString("Detail Name", "")
AddBodyAttribute(temp, "DET_NAME", answer)
AddBodyAttribute(temp, "MAT'L", answer)
AddBodyAttribute(temp, "STOCK_SIZE", answer)
answer = NXInputBox.GetInputString("Surface Finish", "")
AddBodyAttribute(temp, "SURFACE_FINISH", answer)
'input
answer = NXInputBox.GetInputString("Vendor", "")
AddBodyAttribute(temp, "VENDOR", answer)
Next
lw.Close()
End Sub
End With
selBod.Add(temp)
Next
Else
End If
End Function
End Sub
Next
End Sub
End Function
End Module
~Felicia H.
NX 9.0.2.5
I discussed with GTAC and there's a great tool to create an NX dialog box called 'Block UI Styler' which I would love to use but don't have the required Dialog Designer's license.
Big bummer...
~Felicia H.
NX 9.0.2.5
