NX12 - Dimension Text Not Visible When Printing 1
BrittToolEngineer
Aerospace
Greetings:
I have a design where I'm drafting a component and all lines and text are visible. When I go to print, all lines including the dimension lines show, but the text does not show. Can someone help me with this issue?
Thanks,
Brent
Are you printing in color? If so, I'd suggest opening the drawing in NX, turning off monochrome display (if needed), and checking the color of the dimension text. If it is set to white, it won't print. If set to yellow (or another light color), it may print, but, for all intents and purposes, be invisible on the page. Be sure to check the actual color of the text; if "wireframe contrast" is turned on, it may appear to be a different color on screen to increase its visibility.
www.nxjournaling.com
