When we flattening a surface, it allows you to select objects to transfer.
When we transfer a point that has an attribute attached to it, the new point will have that same attribute. However, if you select a line that has an attribute, the new line is a spline and has no attributes.
Is there any way to carry over the attributes on a line?
Ken
My brain is like a sponge. A sopping wet sponge. When I use it, I seem to lose more than I soak in.
Ken
