Sure, I'll try to clarify.
When you run the "2D verify" on your NC program, you have the option to "save in process workpiece(IPW)".
This workpiece can then be used for other operations further down the tree.
Now, unless you change some of the IPW settings, this IPW will simply become part of your database, and it makes your file HUGE.
Ok, so, once you save an IPW, and your database has become HUGE... Is there a way to reverse this? delete the IPW.
Remember, the IPW is not a component...it's not a body...It's totally unavailable to select or to view...It's simply stored as data in your file. Can I get rid of the data and bring my file size back to original?
JAY
