NX6 license server on VMware virtual machine?
nxuser74
Automotive
SI
Hi to all.
I tried to execute ugs_composite.exe file on this VMware virtual Windows XP 32bit OS, but it simply does not execute.
If I try same thing on guest OS (Vista 64bit) then I normaly get composite ID. Can I use this ID on VWware Windows XP virtual OS?
Or is there something that I'm missing?
Thanks in advance.
It should work. i have done it. It might depend on how you are connected to the virtual machine, rdp, vlc, etc when you try to get the composite host id. Other then that it should be business as usually.
