NX9 Drafting : Can no longer grab dimension if placed over the "solid area"
stephlouv
125
If I place dimension over the "solid area" of the model.
It become really difficult to select it as the "infer" selection tool give a kind of priority to the solid model.
I have to wait for the "QuickPick" and select the dimension.
After that, I double clic and I'm able to change options but still can't drag it.
I can edit his position but it's far less conveniant.
(Yes, automatic positionning if turned "OFF" )
Any idea ?
"My english is bad ? That's why i'am french."
Restarting NX solve the problem. But it append again from time to time :-/
If this problems seems to recur on a regular basis and if you get a hint of what might be causing it, or at least what you were doing before it started to happen, I would recommend that you contact GTAC and have them look at this.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
OK. I'll try to be attentive when this weird behaviour happen again.
I've got the feeling it is linked to a new section view creation but not sure.
do you ever remote in to your workstation? I have a similar problem if i remote in then try to work from it later with out starting a new session and restarting
Ryan Lee
Mechanical Project Engineer
NX 6.0.5.3
NX 9.0.1.3(Testing)
If you can think it it can be modeled
