alexsasdad
I am using the same o-ring twice in an assembly. The problem is that I use two different installed congiurations. The gland designs are different and therefore the installed shape is different. I specify that each configuration use the document name for the BOM. When I place a BOM on the drawing it shows each configuration as a seperate item. Items 2 & 3 are the same part number yet seperate items. Can SolidWorks automatically combine these? I thought it would since I told it to use the document name.
Thanks,
Mike
Thanks,
Mike
