object snap settings of catia?
hi friends. i am working on part modeling of CATIA. while i was using sketch i can't select midpoint, endpoint..etc. can anybody solve my problem, please. thanks for your contrubutions.
I've had a similar problem. So far my solution has been to create a "point by clicking" at any near by location, then constrain the point to the line or circle either by dimension or by concentric constraint. You also might want to click on the "construction geometry " tool first.
If you are running CATIA on a PC, you can delete the contents of CATsettings directory (or something like that, I don't remember the exact name of the directory).
When you will restart CATIA, the software will create again the default settings and maybe your problem will be solved.
Fernando
thanks for all your helps. i have found the solution. while working on part modeling i define a point on where i want to snap at sketching. than at sketching i draw e.g circle and than i select both the center of circle and my defined point and than i say coincide from constraints menu. have good working to all my friends and all catia lovers.
CATIA IS ALWAYS THE BEST OF THE BEST............
