I looked for this problem and it seems that someone has already asked it on a forum but unfortunately didn`t get an answer
The problem is with offset curve in Sketch environment. I projected some curves into sketch and wanted to offset them. I get a message saying "Offset is not well-defined for the given parameters"
Have a look at the attached prt file. Go to sketch and try to offset projected curves.
Strange thing is - when I want to offset the same curves in 3D - it works fine.
I attached prt file. This is NX9 file.
Link to original thread.
