This is just something I'm curious about. What is the Overhung Load calculation really telling us?
I can't justify the OHL calculation in my head. Why would increasing the rpm reduce the OHL (be more favorable) for a gearmotor? If one doubles the output rpm then the OHL is reduced by a factor of 2.
From Dodge gearmotor catalog and Rexnord:
OHL (lbf) = (126000*HP*Fc*Lf)/(PD*RPM).
HP = motor horse power, Fc = Load Connection Factor (1.0 for a chain on sprocket), Lf = Load location factor(1.0 for Dodge gearboxes), PD = pitch diameter.
Obviously this formula is a simplification of some factors at work on motor durability. Each gearmotor is rated for a certain Overhung load, and one uses the formula to help select the correct package.
Certainly the fatigue cycles would worse at higher rpm, so this formula must not be addressing that issue. What useful info does it tell us?
