doomster
Chemical
- Feb 4, 2019
- 45
I want to modify a design on our existing gravity oil water separator so that it can cater 20 m3/h of oily wastewater from a wash bay. The highest oil concentration that was experience was 300 ppm. We have an existing oil water separator that has a capacity of approximately 2.4 m3 but still fails to comply to the Clean Water Act effluent requirements. The concentration of oil and grease in the effluent must be below 10 ppm for it to pass.
I have attached the snip of our design of our existing gravity oil water separator.
If you could also suggest a coalescing plates supplier that can supply it here in the Philippines much better.
Thank you!
Thank you!
