doomster
Chemical
- Feb 4, 2019
- 45
I want to modify a design on our existing gravity oil water separator so that it can cater 20 m[sup]3[/sup]/h of oily wastewater from a wash bay. The highest oil concentration that was experience was 300 ppm. We have an existing oil water separator that has a capacity of approximately 2.4 m[sup]3[/sup] but still fails to comply to the Clean Water Act effluent requirements. The concentration of oil and grease in the effluent must be below 10 ppm for it to pass.
I have attached the snip of our design of our existing gravity oil water separator.
If you could also suggest a coalescing plates supplier that can supply it here in the Philippines much better.
Thank you!
Thank you!
