I have a degree in mechanical engineering. I should be able to call myself an engineer, or a mechanical engineer. I should not be able to use those terms if I do not have a degree in mechanical engineering. (I know there is some slack in this because I didn't say accredited, and an unaccredited degree could range from a printout from a website to a good engineering school that is working towards accreditation, but I digress) I should not be able to use the term Professioanl Engineer unless I have passed the PE test. This is what logic and common sense dictate. Everyone else and the law is wrong. As for the term engineering in a buisness name I'm not as sure.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
-Kirby
Kirby Wilkerson
