I'm a new mechanical engineer, and one of the projects I’m working on involves a good amount of structural steel for a suspended platform/walkway. It has one main beam that spans the length of the platform, and several cross members connecting that beam to another parallel beam for support. (Imagine your typical horizontal truss/walkway, where the cross members are all perpendicular to the main supports.) My question is this:
Assuming the beam is supported at the same points along its span either way, is there a significant difference/benefit to breaking the beam (which is wide flange by the way) up into shorter pieces bolted to one another? Would this eliminate additional bending moments, or is this already taken care of by the intermediary supports?
Thanks in advance!
Thanks in advance!
