g56casey
- Aug 21, 2008
- 4
I am currently using ANSYS Workbench to perform a Static Structural Analysis on a complex 3d model. I uploaded an assembly from Pro/E for the geometry of this simulation. I have read previous posts about this problem and have had no luck. I set my forces, supports, and pressures, and when I solve, I get displacements such as the one I have in the attachment. I also get that error in the subject as well as
"Warning: Solver pivot warnings have been encountered during the solution. This is usually a result of an ill conditioned matrix possibly due to unreasonable material properties, an under constrained model, or contact related issues. Check results carefully."
I was wondering if anybody had any possible work-arounds for this problem.
