rfd23
- Nov 9, 2007
- 42
I have a circular bin supported by 8 columns. Bin dia is 12m. we are using a octagonal pilecap with 56 piles. I am using 1.5m deep pilecap. otagone has 17m dia. To check the one way shear at d from the face of column, I am having 30 piles contribute to that section. shear capacity of 1.5m mat with 30Mpa concrete is far less with 17m width. Even I am reducing shear by column loads in that section. I cannot increase the depth otherwise my piles will be overstrsed.
I can not put more piles due 3d spacing requirement.
1. Should i check one way shear based on pile capacity or actual reactions from various load combinations.
2. Is it normal to provide shear ties in a pile cap with scattered column on the top.
any reference material related to large pilecap is greatly appreciated.
All useful thougths are welcome.
Thanks in advance.
Thanks in advance.
