We have a job that falls under part 11 of the Ontario Building Code. This part deals with renovations. We are adding a new mechanical unit on top of the roof of a hospital, a post-disaster building. Part 11 doesn't require the existing building checked for seismic. However, new building systems need to conform to the current code. A mechanical unit is a building system. So, do we need to provide seismic restraints for the unit and its ducts?
My understanding is yes, because, although the existing building is not built to the current code, it might possess a capacity to resist the next seismic event and therefore we should not assume it will fail.
Others see it differently; they say: the new unit is supported by the existing building, so if the building is not built per the current code, we should not ask for restraints required by the current code for systems attached to it.
Any help is appreciated. Thanks
