DirtSmuggler
Geotechnical
I'm looking to open up the attic in my personal home. I attached a rough sloppy sketch. The top is how the frame is currently in the attic. The bottom is how I would like to frame it to open it up. The dash lines are where the perpendicular part of the attic. Is this set up fine for the structural stability of the attic. And if so, why wasn't this done when built to give owners better attic space? If not, then what do i need to do to open up the space but still make it structurally stable?
It's a triangle prism roof with another triangle prism perpendicular to it. It's one unit in a building of 5 townhome with neighbors on both sides. [URL unfurl="true"]https://res.cloudinary.com/engineering-com/image/upload/v1713902793/tips/DOC018_grbnuj.bmp[/url]
If i need to hire a structural engineer for this, what should I expect the cost to be? It's a 600 square space area.
