Optional type of flange 8a (ASME code)
Is this a silly question?
As per ASME code, that flange can be calculated as integral or loose, but, in my opinion, the code is not 100% clear about what are the h and g1 dimensions to be considered.
If I look to sketch 7 it seems to me that I have to consider only dimensions of weld fillet, but, if that's the case, it doesn't make sense to use a hubbed flange.
Any thoughts?
Thanks.
You are using the old edition.
r6155
r6155 is correct. See Note (6) in Figure 2-4 in the 2015 Edition - will be on page 376. This should answer your question.
