A colleague shared an interesting twist with me today and I'm not sure if it's sufficient to qualify a vessel. They were doing Sec. III work. They plotted stress intensity on their ANSYS model. It was not a "linearized" stress intensity plot; instead, it was just an ordinary stress intensity plot. They said that because the stress intensity everywhere on the model showed it was below the S Code limit, the vessel therefore qualifies. In other words, everything in their plot was below the Primary Membrane limit, S, which is the most limiting qualification, which means the vessel therefore passes all qualifications (i.e., general membrane, local membrane, primary membrane + bending, primary + secondary).
They never inserted any stress cut lines to do linearization and touted this method as a shortcut to avoid having to create many linearization paths throughout the vessel. This sounds like it could be a viable shortcut, but I have never heard of this approach before. I wonder if regulators would buy into the story if they saw this in a report. Can anyone shine some light?
