Modeling this in CAESAR would give you a defensible estimate but it will be far from an accurate answer. The load calculated by CAESAR will be the reaction needed at the nipple-to-flange node to create a stress level equal to the max allowable developed in the pipe for whatever load case you are modeling. Note this does not really account for the stress riser at the threads, which is critical, except for the reduced wall thickness. The SIF for a threaded connection is a fatigue-based derating factor that will, as I said, get you a defensible estimate. Also, if this is in vibrating service, there are additional considerations. If you need a better number than CAESAR, it should be modeled in FEA. Bottom line, best to decide how accurate of an answer you need, then proceed. If all you need is an approximate number you can defend with documentation, I'd use CAESAR, then derate that value by 20% or by some other appropriate factor. This will protect you if, for example, some dude decides to stand on the flange taps, and it snaps off. Ask me how I know about that one sometime. LOLz
