OSM_D019 : Invalid Data reading
Pechkit
9
Hi all
Has somebody already seen this error message:
I just want open a CATDrawing and i can't.
Help Please!
I believe this is a version error. Have you opened and saved this file with a version of catia that is newer that the version you are using now?
Hi Pechkit,
What level are you using? R10SP3/4??
Check this APAR HD06009 in Tech support website or ask your PLM Support for details.
Kennis Tang.
Thanks for your help, I'm using R10SP4 and i would like to know where i can get the tech support website?
Can you give me the web adress?
Hi Pechkit,
Yes, go ahead to register on the PLM Support Website
and find out new things over there ...
OK ... APAR HD06009 is closed and concludes that
the problem is fixed on
V5R10+SP7
V5R11+SP4
V5R12GA
Cheers. Kennis Tang.
Thank you very much to all!
I found it!
Regards. Florent PAPINESCHI
