I have four lifting lugs on a skid. The lugs are unstiffened vertical flat plates (with cheek plates) that go through the flange of the skid member and weld to the top flange, bottom flange, and web of the skid member (lug is aligned with the web of the skid member). The skid is being lifted with a spreader bar. In order to avoid a conflict with steel above, I have to have an outboard angle of about 8 degrees but I've not planned to pre-bend the lugs to match this angle.
In all the literature, there are guidelines for accounting for the out of plane load on the lugs. I understand this requirement if the lug is very stiff and might cause excessive torsion to the member to which it is attached, particularly if the lug is attached at a point where there is little resistance to torsion. I have addressed the torsion issue by locating my lugs where there are fully welded lateral members in the skid. It is a very stiff point - much stiffer than the weak axis capacity of my lifting lugs (strong axis bending in a heavy wide flange beats weak axis in a 1" flat plate). Can I not allow the flat plate to deflect in the direction of the tension load, much as you would consider a fan plate rod?
