Overhead Crane Frame Design Reference
McSEpllc
108
Does anyone know of a good overhead crane frame design reference?
Thanks.
Eric McDonald, PE
McDonald Structural Engineering, PLLC
You can check out this publication for free from the Canadian Institute of Steel Construction:
There are two big and complete design examples all the way at the end. Of course, this publication follows the Canadian Code though I'm sure there are a lot of great information that you can pick out even if you happen not to follow the Canadian Code.
If you are a member of AISC, you will be able to find similar guides for free.
Try Crane Manufacturer's Association of America (CMAA) documents
CMAA 70 - Top Running Bridge & Gantry Type Multiple Girder Electric Overhead Traveling Cranes
CMAA 74 - Top Runing & Under Running Single Girder Electric Traveling Cranes Utilizing Under Running Trolley Hoist.
Section 3 of both documents gives structural requirements for design. There are multiple posts on this forum about crane design if you search for them.
