Fac_Eng
- Jul 16, 2020
- 5
Hi all,
My plants instrument air header is designed for 150 psi and operates at around 100 psi. The IA is then typically let down to 50 psi or so by a small regulator when used for valve actuators or pneumatically driven pumps. I assume that if you connect a typical control valve diaphragm actuator like a Fisher 667 to pressure source and slowly increase the pressure, at some pressure it is going to fail i.e. it has a maximum pressure rating. But in googling and reading product datasheets, I do not see the "MAWP" of a diaphragm actuator discussed anywhere.
I'd like to understand why we don't include PSVs on the downstream side of instrument air regulators that feed into things like valve actuators. If I don't know the MAWP of the end device how can I know that it cant be over pressured? I don't think I have ever seen a PSV installed between the letdown regulator and an end device so clearly I am missing something.
Thanks!
Thanks!
