P00153 I.F ERROR 1
Thanh Tran
Industrial
Jan 7, 2021
33
Hi, I ran the stimulation of a program on Mitsubishi 40CFX laser and got this error. I used the MetaCam software to encode the program from dxf file. What’s the cause of error? I tried to skip one command life then the next line will be error.
 https://files.engineering.com/getfile.aspx?folder=2b05dda4-291d-4ff2-9f8b-8838395bc50d&file=389ABDF6-6F73-4EE0-96DB-415C142D04D1.jpeg
looks to me like your cut lines are outside table dimensions
You have a problem with wrong offset i your program vs the controller.
Might work too set the errorcheck or something like that in the on/off menu.
Have too check my books too be sure.
I deleted the command lines where the errors occurred and the problem solved.
Basically you have an interference error and likely it's on cutting/etching the letters. This happens when you have small line segments that are smaller than your offset. For instance, you have a small line of 0.002" and your offsets are all set to 0.004"
(SET-CUTTER-COMP)
#2001=.004(D01)
#2002=.004(D02)
#2003=.004(D03)
#2004=.004(D04)
#2005=.004(D05)
You can either reduce your offset to 0.000" or change all your G41/G42 to G40 in the NC Code. This cancels cutter compensation.
Hope this helps next time
