rhmeng
Aerospace
- Apr 9, 2015
- 77
I have a surface on a part that I am dimensioning w.r.t to a surface Datum A. If I put a dimension X +/- .001, is there no point in putting a // to Datum A of .002/.003? Because the plane has to lie within that tolerance from the +/- .001 anyways correct? Also for the same surface, if I callout // of .004 w.r.t Datum A, that is sort of like saying the flatness of the surface is also .004 right? Seems like when you get to tight tolerances flatness, +/- and //ism go hand in hand and sort of say the same thing.. Thanks in advance
