Patterning fasteners
fighterpilot
Military
Scenario: Plate in assy w/ 5 holes. Holes are not part of a pattern in the plate. Have fastener, would like to place one fastener in a hole with surface contact and coincidence constraint. Now, how do I get the other 4 holes populated w/o placing each individually? I'd like to pick the surface, define it as common to all fasteners, and then select the other 4 axis and have them populate.
V5R14SP1 on Windoze 2K
Thanks for the assistance.
Yah, you've got to be careful with saves in CATIA.
So were you prompted in Pro/E to overwrite a file with whatever is in memory? That seems dangerous.
Config,
Yes....But. Pro/E would store files like 1.prt.1, 1.prt.2, 1.prt.3, 1.prt.x and so on and so forth. If you happened to overwrite a file you could just go to the disk and delete the latest saved version. Or, if using Intralink, just undo the save and you are back to where you started.
Interesting... when does it store them? On the closing of a window?
Stores them to disk when you hit save. If you just close the window there is a way upon file/open to either pull from the disk or from memory. It warns you if you pull from the disk if a later version of the object is already in memory.
