PCP Pumps
sul1948
Petroleum
Feb 27, 2003
1
We have shallow oil wells in Kyrgystan ( 100-170 m depth); Low pressure, low rates.Would someone help me in locating manufacturers/ suppliers, they can design and install.Furthermore where can I get more information as to their utility, efficiency, design, etc.
sul1948:
Numerous manufacturers and suplidores of PCP exist, most of them can make the design and installation, nevertheless I recommend to you that you must participate in the design, since they know their equipment, but
you know your wells.
It is important that you provide with exactitude the bottom hole data, is to say: pressure, temperature, viscosity, oil gas relation, water cut, etc. as well as the rate that you expect to produce, characteristics from wells like total depth, depth of the perforations, type of
well: vertical, deviated or horizontal, casing diameter, tubing diameter, well head pressure, etc.
Hi, i recomend that you participate, in the desing. You must to know all the parameters of your wells, for make a good desing and contract an engineer production specialist in artificial lift. You can go to Weatherford, that is the company that supply where i work, and make a very good job.
I'm a production engineer, specialist in artifical lift, so i can help you, that if you wish. You can write to me in the next electronic address carlos.a.figueroa@petrozuata.com.
regards.
