KernOily
Petroleum
- Jan 29, 2002
- 711
Hi guys. Not sure this is the right forum, so please recommend an alternate if I need to move this post. I have two PD lobe blowers (Gardner-Denver GGB type, 15 hp each) that my client is proposing to put in series to meet a ~30 psig discharge pressure requirement. These are surplus equipment items they want to re-use, so purchasing new equipment is a non-starter.
The proposal is to use these blowers to replace an existing air compressor that cycles on and off to meet the load, which is 170 scfm.
I am certain I will need an intercooler and intercooler separator vessel. Also, I believe force feed lubrication is needed for pressures over 20 psig so I would have to figure that part out.
Beyond that, will this work, or should I run the other way?
Thanks in advance!
Thanks in advance!
