PDF plot
uni1
IT
hy again guys, thats another problem bothering me in these hours: PDF exporting
look at the file attached: if u zoom very close, to see little details for example bathrooms, u will realize the drawing isnt perfect as it seems when zoomed out! if u zoom in you will see like pen-drawn-lines, like a freehand drawing.
well this effect is very interesting but its NOT what i want now!!!
do some of you know why this happens and how can i fix it?
thanx
(some lineweights are pretty random, im still working on it)
uni1,
remember: We do not know you Acad-vision and the way how do you create the PDF-file...
Lothar
ADT 2004
erghh...autocad 2007
plot->dwg to pdf printer.
CTB plot style: monochrome
i tried with a coloured plot, just to see, and well the problem is the same but a bit less... u can see in the other file i uploaded
thanks
 http://files.engineering.com/getfile.aspx?folder=901b3ac2-d954-4d8f-a085-2ba99c54f16b&file=upload2.pdf
PDF FILL pdf writer seem to work pretty good and I think it is free
pdf995 tool is a good one to, works well with most AutoCAD features. First one I found that handles wipeouts well.
Zuccus
uni1
Interesting problem. Have you tried to do a regen before print to PDF ?
I sometimes get a funny looking toilet on PDF but by doing a regen it fixes it. I use Nitro PDF for printing. Also do you get the same problem if you publish the plot?
Cheers!
well, it works slightly better with a regen...but it isnt enough. i tried the pdf convertor and it looks like crazy lines are fixed, but minimum lineweights are hell thick as shown in the file...
thanx
Regarding the PDF quality . . . I found that while you are in the PLOT screen, and you increase the quality to maximum, then your PDF will be nice and sharp as you zoom closer and closer.
I have the best luck with PDF995 software.
-Rocky
Cheers . . .
I think your expectations may be a little high for a pdf converter. The output you uploaded, if plotted to a 24 x 36 piece of paper, would probably look fine. When you zoom in to 6400% (the limit of Acrobat) then it gets a little heavy with the linetypes. However, if you plot a smaller window, saw one of those buildings to some scale like 1/8", the linetypes should be more reasonable and give you a better looking bathroom when zoomed in to 6400%.
Don Phillips
