Can someone comment on their experience classifying Jacketed Pipe (JP) for PED
From Guideline B-04 it sounds like JP would be classified as a vessel if the fluid designed to flow through the core pipe (secondary fluid) was anything but air. If that is the case, Guideline B-19 would seem to classify the JP as a chambered vessel in which case one would use the pressure volume and fluid of each the jacket and core to determine the PED category of each. The highest PED category would then be used.
If this is the right approach, would one consider the volume of the core chamber of "the vessel" (i.e. JP spool) up to the flanges?
