mehrdadkntu
- Jan 31, 2015
- 8
As you know, the pump manufacturers supply their pump performance curves with nominal minimum and maximum impeller diameters and some diameters within this range for a particular model.
I received one proposal from a manufacturer in which a pump model had been selected for our process condition with the Min, Max and rated impeller diameter in its performance curve.
Due to change in our process condition, we requested the vendor to revise his proposal. In his second proposal, he had selected the same model for the new process condition, but he had changed the max & min impeller diameters to select the rated impeller for meeting our new process condition.
What is the criterion for determining the max & min impeller size for a particular model of a centrifugal pump?
In a particular model of a centrifugal pump, is the max/min diameter of the impeller fixed or they can be changed by vendor according to the conditions?
my another question is that how the rated impeller is fabricated.is it fabricated by trimming/cutting the max impeller down to the rated diameter or the vendor redesign and fabricate it separately?
