Perspective looks wrong
odye
Industrial
Oct 6, 2004
1
0
0
I noticed that the vanishing lines do not diminish into space as they should in perspective. Is there a way to make the perspective appear to be right?
VIEW/MODIFY/PERSPECTIVE You can change the number to adjust the perspective. The lower the number the more the distortion. Also panning the model allows for some fine tuning of the perspective.
Further problem I experianced is, if you want to use that modified perspective in the drawing utility, it goes back to its default. so modifying perspective in draving is useless, unless there is another trick...
