CheemaJ
Chemical
- Mar 8, 2019
- 21
The plant I am working in has experienced some very rapid and localised corrosion on 316 stainless steel process pipework. It is almost entirely around the heat affected zone. See attached document showing some photographs of this. The duty is a clean in place return line. To mitigate the issue going forward we are going to replace the pipework with a new welding standard (to reduce oxidation) and also pickle and passivate before putting into service. On welds that our fabricators can access (i.e. union joints) they tend to mechanically polish the welds. I was wondering if there is any advantages or disadvantages to doing this given that all the welds will be pickled anyway.
Thanks in advance.
Thanks in advance.
