Pile Buck (SPW911) - Terzaghi Pressure Model
justhumm
112
I'm playing with a sheet pile wall design (in Pile Buck SPW911 ver. 2.0, with tie backs) in a mostly soft clay soil; and (as per the software's error message) am analyzing it using the Terzaghi Pressure Model (which I assume is based on Log-Spiral theory).
I am interested in finding some more background and theoretical information on the variables used in that model (specifically, m = 0.4 or 1.0 and a = 0.2 - 0.4), because when I change one of them, I am getting wild variations in the results.
There is a little bit of information in the old pile buck design manual (1987, pg. 22 and 119), though I am not gaining a lot from it.
If anyone can shed some light on the Terzaghi variables (m and a, as used in Pile Buck / SPW911), or if anyone can suggest a good reference for them, I would appreciate it.
Thanks.
It's been a while since I've dealt with SPW 911, but let me shed some light on a point or two.
First: "Terzaghi" earth pressure has nothing to do with log-spiral slip surfaces. It refers to the Terzaghi & Peck trapezoidal earth pressure distribution traditionally associated with braced excavations. The only other options in SPW 911 are Rankine and Coulomb earth pressure theories.
Some information on the m and a variables can be found at the "Terzaghi & Braced Cofferdams FAQs" page
You said you're using 2.0. I'd try to obtain a higher version; some of the features were expanded and, of course, some user-spotted difficulties were addressed. Also, Pile Buck's replacement for the PBSSPDM is Sheet Pile Design by Pile Buck, which can be found at
It includes some worked examples using SPW 911.
It's also worth noting that most of the theory in SPW 911 was taken from the BSC/Ciria books on the subject.
