I am tring to calculate loading test of small scale pile in ABAQUS CAE. Results which I get are rediculus. I am afraid it can be connected with invalid definition of geostatic state of stress (gravity g=10 m/s). I checked the units but there is ok with them.
Axisymmetric model dimensions:
Part-1 : 0.5m x 1m (horizontal x vertical) with 'hole ' for pile 0.035m x 0.45m (horizontal x vertical)
Part-2 : 0.035m x 0.45m (horizontal x vertical)
My dry sand is modelled with Mohr-Coulomn
density 1450kg/m^3
Young modulus E=40e6 Pa
Poisson ratio ni=0.3
friction angle fi=33deg
dilatancy angle psi=10deg
cohesion c=100 Pa
Pile properties (Elastic):
density 2400kg/m^3
Young modulus E=20e9 Pa
I define initial state of stress( EALL - set which is whole model soil+pile) by
*initial conditions type=stress, geostatic
EALL, -14500, -1, 0, 0, 0.5
When I check Frame-1vertical stress is like I defined and no vertical dispalcement occures
Frame-2 vertical stress changed (caused by the weight of pile) and significant values of displacement occured (also S12 and CSHEAR1 are not equal to 0)
Interaction between soil-pile (created in Initial step and propagated to all): tangential - penalty - friction coefficient 0.35
Two steps:
Step-1: Static, gravity load (whole model)
Step-2: Static, gravity load(propagated tron previous step) + displacement on the pile top (d=0,05m)
Problem is that the concentration of vertical stress is in soil under pile tip not as I expected in the pile head.
Does anybody know what can caused this kind of behaviour? and what is more important how to fix it?
Thank You in advance
Anna
density 1450kg/m^3
cohesion c=100 Pa
density 2400kg/m^3
Two steps:
Anna
