Lion06
- Nov 17, 2006
- 4,238
I have a somewhat theoretical question regarding concrete walls as they are a reasonably popular topic of discussion on this forum.
I, as many others, often design concrete foundation walls as pinned-pinned when there is a first floor diaphragm to tie into. I understand people have been doing this forever and I am not questioning the practice. My question is this: Is a pinned base really able to be achieved in any typical detailing that anyone does?
I am thinking that any rebar tying the wall to the footing is providing some moment capacity. I understand the pinned-pinned case is the worst case for the wall, so that is being conservative is you get some end moment capacity out of the foundation to footing connection. Assuming a pinned base is unconservative for the footing since there WILL be some moment at the base. Even if the steel yields and a "plastic hinge" forms at the base it doesn't lose its moment capacity.
Also, there must be some steel at the interface of the footing/wall since they are usually seperate pours and the steel is need for shear.
Any opinions on this would be greatly appreciated.
