Blobajob88
Chemical
- Jun 3, 2019
- 13
I'm hoping someone can help me. According to Bernoulli's principle, when water is flowing through a pipe and the pipe restricts in some way, the velocity increases/pressure decreases through the restriction and then ramps back up to the velocity and pressure it was originally at once it gets through the restriction. My question is: Is this only applicable up to a certain point, for example if you're pumping say 20 m3/hr through a 2" pipe and the pipe then restricts to something minute, say 2mm, surely there will be a pressure build up?
