TJH2161
- May 15, 2020
- 12
Working on a project where we are pulling our altitude valve and bypass line out of an underground pit at one of our elevated storage tank sites. We are relocating into an above ground building for better access. Building will be situated on a slab on grade. We will have a pipe penetration through the slab. Any suggestions on how to isolate the pipe from the slab? I was thinking of maybe wrapping the ductile iron pipe with some sort of asphalt expansion joint material. I'm thinking if we just pour concrete right up against the pipe penetrating the slab, it will crack relatively soon after construction. That's how it was done years ago for our pipe penetrations in our water treatment plant, but it looks sloppy. We will be using adjustable pipe supports so I am not worried about differential settlement between the building and the pipes. Any ideas or thoughts are greatly appreciated.
