yanuarsaja
i found in some calculation procedure/criteria from various spec to calculate thickness of piping:
1.
a. For Class 150 and 300 systems: The maximum pressure rating in accordance to the
Temperature- Pressure Rating Tables in ASME B16.5 is used.
b. For Class 600 and above: Design Pressure based on the Temperature-Pressure range
for each piping material class.
and
2.
Wall thickness calculations shall be based on the following:
(a) For 12” and smaller: To use TEMPERATURE-PRESSURE RANGE of each piping material class
specified in ASME B16.5.
(b) For 14” and larger: To use most severe condition of each line.
the both methode are different, 1 based on rating, and the other based on size, (both are comply with 31.3)
what is normally used in the Industry to determine thickness?
thankyou.
Yanuar
1.
and
2.
thankyou.
Yanuar
