tnteng
- Oct 24, 2002
- 58
Can anyone help - I am designing a spreader bar and will be using pipe as the spreader bar. The padeyes on the top and bottom of the spreader bar will be made of one piece of flat bar that slides through the pipe and is welded to the walls of the pipe. I have checked the buckling in the pipe due to the compressive loads of the padeyes and I have checked the stresses in the padeyes themselves as well as the welds that hold the padeye plate in the pipe. My only concern is what local stresses the pipe will see due to the loads that the padyeye plate imparts to the pipe (bearing or buckling) and how those would be checked.
Any suggestions?
Thanks,
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
Any suggestions?
Thanks,
Tony Billeaud
Mechanical Engineer
Franks Casing Crew
