francis2013
- Nov 19, 2013
- 3
Dear all,
I am new to write in this forum. I spent some time on it and I found very good quality and interesting discussions. I would like to open a discussion on piping stress analysis. Maybe there is already a discussion about what I am writing, but I do not have enough time to go through all the posts. I have to say that I am an engineer new on piping. My colleagues asked me to perform a pipe stress analysis and I do not have lot of time. I already read some books that suggest to divide the pipes in simple supported beams in order to simplify the calculations. My principal point is about the constraints induced by the support, in particular for U-bolt. My colleague suggested me to consider that the U-bolt will allow all the rotations. Than all the translations are also blocked. In particular regarding the longitudinal axis the friction load from the tightening of the bolts is able to constrain the weight and the seismic loads, but will allow the thermal expansion of the pipe. Do you think that these assumptions are correct? I ask this because I found on literature different contrasting questions, and I think that the experience could count even more than books.
Thank you all in advance
Best Regards
Best Regards
