thryll
Chemical
- Oct 23, 2002
- 26
Does anyone know of a company which can plasma coat inside a two inch ID pipe as they do in turbine coating. The pipe is approx 54 inches long, hastalloy X material and will be heated up to 1700 C I am currently using extruded alumina tube but it is very fragile. I would like to switch to a high temp alloy. possible? The pipe needs to be 100% protected against corrosion inside. Diffusion alluminide bond coat, outer coating partially stabilized zirconia?
Conmments please
Thanks guys and gals
Conmments please
