3800sc
- Jul 14, 2010
- 8
hello,
I am working as an engineering intern at a nylon production facility and am trying to determine how to capture caprolactam that is released from our pellets that are dried under heat and vacuum in a conical dryer.
The problem is that when it is released it moves into the vacuum lines causing clogs in the lines and over time makes its way into vacuum pumps and damages them.
The facility currently shuts down the entire drying system every three days or so and steams out the lines and dryers which is a considerable amount of down time as this takes at least 12 hours
Does anyone have any recomendations as to a trap or condensor that will work well to capture the monomer when it sublimes from a vapor to a solid
